Spec or Monster?
Old 09-21-2009, 01:56 PM
223HAWK's Avatar
Default Spec or Monster?
My Firehawk is going to need a clutch soon. Im looking to get the Spec Stage 3 or the Monster 3 with a light weight flywheel also. Iv heard good about both just wanting more thoughts..Its not a race car just a toy. Do I need to replace the slave when I do a clutch? 60,000 Miles, No leaks..No a daily driver..
Old 09-21-2009, 02:02 PM
tko0383's Avatar
replace the slave while you are there.
Old 09-21-2009, 02:07 PM
youngrigo's Avatar
Replace slave and get a Monster!
Old 09-21-2009, 02:15 PM
SPEC-01's Avatar
What are you planning to do with the car? Also, what kind of torque do you plan to make? I ask because we have recently released our Super-Single 12" clutch kits for the LS1 application and these kits provide great capacity and drivability. This may mean that you don't inherently need a stage 3...and that you could subsequently use a lesser stage to fit your needs. Of course the stage 3 is a great option I just want to insure that it is what you both want and need. Let me know. Thanks,
Old 09-21-2009, 03:43 PM
223HAWK's Avatar
Its a Heads Cam car now puts down around 425 rwhp now..with a bottle or something else Ill prob do later..I want to make sure Im safe. Its mainly a show car and just nice days get it out. Ill get it out and play when someone wants me to..but its not a race car.
Old 09-21-2009, 05:01 PM
SPEC-01's Avatar
With your planned use in mind a Stage 3 may be a bit agrressive. It's pucked disc design means that it will have a rather quick engagement and that it will also be more prone to chatter. That being said if you want smoother actuation and good capacity to boot a stage 2+ would be great. It is rated to 782lb.-ft and having driven one 62-miles round trip in my last car I can tell you from experience that it is easy to deal with on a daily basis. Let me know if you have any further questions and I will be happy to assist you further. Thanks,
Old 09-21-2009, 05:18 PM
CaMaRo67RS355's Avatar
spec 3+ JUST DO IT i almost drive mine everyday
i love mine, never had experience with monster though
Old 09-21-2009, 08:24 PM
a383z's Avatar
I just put in a monster stage 2 this saturday and no issues whats so ever. I like it so far and am half way thru my break in mileage
Old 09-21-2009, 09:20 PM
Blk98ls1's Avatar
Monster Level 5 here. Just do it the right way the first time and buy a clutch that will hold way more than what you need. My car is a daily driver and the Level 5 is perfectly fine. I had a Stage 2+ SPEC and it just didn't feel right even though I was only making 400 wheel, The Monster grabs and holds way better. I'm also really safe if I want to throw Nitrous at it. I'm sure SPEC has a good product, but with my experience Monster is better.
Old 09-21-2009, 10:18 PM
Chesty for President's Avatar
I had a spec stage 3 in mine and it was a good clutch. I ordered a 12" Diamond stage 3 clutch from Jason at TDP and is freaking awesome. Ill run them from here on out without question. Give Jason over at TDP a call 817-300-6840
Old 09-21-2009, 10:36 PM
223HAWK's Avatar
I think I like Monsters stuff from what Im reading. Im going to do the 15lb flywheel at the same time. I totaly agree that go bigger just in case..Im sure that It will get at least a 150 shot before to long to keep up..
Old 09-22-2009, 08:17 AM
SPEC-01's Avatar
If you are going to go bigger and still want drivability then the stage 3+ would be a great option (this is mentioned above). It is still very drivable and has nearly 1000lb.-ft capacity. I think that most that have driven a Stage 3+ would agree that this is a no brainer. Let me know if you have any further questions. Thanks,
Old 09-22-2009, 08:22 AM
rpmauto's Avatar
I have the spec 3+ for 3 years now, takes a ton of abuse and never a slip. Plenty of n20 and a 402.
Old 09-22-2009, 08:29 AM
Dutchman427's Avatar
Monster here...Very happy. Steve is a good guy to deal with.
Old 09-22-2009, 04:39 PM
223HAWK's Avatar
whats the factory flywheel weigh?
Old 09-22-2009, 06:35 PM
Gen414's Avatar
If in need of a Monster, I can get you squared away.
Level 3 is our most popular setup, by far and away, and even though it is a puck design disc, and you will get some chatter during break in, it will all but go away once break in is finished. If some pops back up after the fact, it is simply because you were to easy on teh clutch...go beat on it and call it a day!
Let me know...thanks
Old 09-22-2009, 10:35 PM
Mikey 97Z M6's Avatar
Monster Level III here. I've driven all the single disk clutches on the market over the last 10 years. You won't be dissapointed with a Monster clutch.
Mike
Old 09-22-2009, 10:47 PM
223HAWK's Avatar
Why does the monster clutches come with flywheels? To save some cash do I really need the lightest flywheel for my slow turd?
sixpack_2_go's Avatar
monster has had a lot better reviews than spec. monster really stands behined their product. i hear great things about monsters customer service.
Old 09-23-2009, 09:20 AM
Gen414's Avatar
Well, why not? If going to warranty a clutch for one year, I would want everything matched, and what better way to do that than supply EVERYTHING associated with your setup?
No, you don't HAVE to have teh lightweight fly...the standard fly is actually our best selling flywheell, with either higher HP cars or lighter cars going with lightweight fly.
I would say that roughly 60-70% of clutches I sell, people elect the Standard fly.
What I tell people is this:
Heavy car (over 3500-3600) pounds, go standard
Lower HP (500 and under) go standard
Track/sticky tires, nominal HP, go standard
If High HP, 600 or more, on the street...go lightweight (will help you hook up better on street)
Or if you have a real light car, and good power, you can go lightweight.
Matter of weight, HP, and intended use (DD, weekend, track only, etc...)
