Spec Twin PT Helped my HCI NA C5Z into the 10s today
Old 12-20-2009, 05:57 PM
Kurtomac's Avatar
Default Spec Twin PT Helped my HCI NA C5Z into the 10s today
Clutch was very predictable, took slip, shifted perfect couldnt ask for more today and a new PB for me too boot! Ive got 5000 miles on it now
Last run of 2009 put my z06 in the 10s NA
Made 4 passes and progressively got faster...after my breakage earlier this year i didnt want to get greedy. Was launching at 3500 with a clutch slip while feeding throttle...the last pass I upped it to 4000 with a little more aggressive throttle feed and clutch release. Came out strong as my gearin is pretty good...nailed my 1-2 at 6900 nailed my 2-3 at 6900 short shifted the 3-4 at 6700 as i knew i had a good pass going and didnt want to bump the limiter like I did on the 3rd pass 3-4 shift...on the return road i seen thumbs up from a few friends so I knew I had it
1.63 60ft
7.06 at 99.7 1/8
10.93 at 128.25 1/4
2002 Z06 22,000 miles
Stock 346 short block with heads, cam, intake, RPM diff and trans, spec twin disk clutch which took a beating like a pro today. It was on 26 11.5 17 Et streets at 16.5psi cold GTO spares and MH racemaster skinnies up front. Safe 12.0 AFR 28 Degrees timing (I tuned it)...Im sure with a 1.50 60ft I could get 10.70s and if I powershifted possibly 129-130 mph. Im sure if I removed my sway bar it would help the 60 as well. Drove it there and drove it back...all is well with no strange noises.
Thanks for the look guys!
Track was Coastal Plains Dragway in Jacksonville NC at 230 this afternoon DA was supposedly -800 ish
Old 12-20-2009, 06:48 PM
LS1Tech Sponsor
Slowhawk's Avatar
Looks good.That clutch will take the abuse.I've run a customers 800rwhp Vette with one.Launch rpm at 6000rpm with a slight slip to 1.4 60's and the clutch took it no problem.Probly had 100 passes on it.
Old 12-20-2009, 06:57 PM
Kurtomac's Avatar
Thanks Don!
Old 12-20-2009, 07:16 PM
LS123's Avatar
Congrats! I know it was a long time coming. See you more often at a track!
Old 12-20-2009, 07:22 PM
Kurtomac's Avatar
would be nice...I gotta sell...I got an assignment to Okinawa Japan for 4 years cant take any cars with me so I got 3 to sell
Old 12-21-2009, 10:59 AM
LS123's Avatar
I'll keep it for you until you get back!
Old 12-21-2009, 11:36 AM
SPEC-01's Avatar
Kurt...thanks for the update! It great to see that you have improved on your previous times and I am glad the clutch is all that you hoped it would be. I do hate to hear that you are heading overseas though and I hope that all goes well for you. Let me know if you need anything else and have a Merry Christmas.
Old 12-21-2009, 04:02 PM
Kurtomac's Avatar
thanks Jeremy!
