T56 Temperature Gauge
Old 02-22-2010, 05:33 PM
matrixiskool's Avatar
Default T56 Temperature Gauge
Ok im prepared to be flamed, regardless I'm wondering where on the t56 I could place a temperature sensor for a glowshift gauge I got. Im not sure if it woud screw in place of the drain bolt or I could somehow secure itsomewhere inside and just run the wires out somewhere. The picture is of the sensor.
Edit: I've looked everywhere about this so please don't tell me to search, just give me a link or explain how I can do it. Thanks
Old 02-22-2010, 06:33 PM
85MikeTPI's Avatar
I placed mine in the fill hole, since I never use that (fill through the shifter). You'll probably need and adaptor from 1/4-NPT or whatever your sensor is, to the 3/4-NPT that the fill hole is.
(Fill hole gets enough splash to get a temp reading)
FWIW, I never found my fluid going above 180F, even after a 20min HPDE session. I rarely ever use the gauge now...
mike
Old 02-22-2010, 06:45 PM
You have a t56? What about an adapter for the drain hole?
Old 02-22-2010, 06:49 PM
85MikeTPI's Avatar
Same size as fill hole.. 3/4-NPT.. My thoughts were if the sensor failed or leaked, I wouldn't burn up my transmission with it in the fill hole..
Old 02-22-2010, 07:00 PM
Ok I found an adapter, I'm thinking if I put lock tight on the threads if I use it on the drain hole?
Old 02-22-2010, 07:04 PM
85MikeTPI's Avatar
Loctite will help. I'm just a pessimist at heart and didn't want to risk my trans for something that's works perfectly well in a hole that won't drain my trans..
The late model vettes have another 3/4-NPT port on the LHS of the case where they mount a temp sensor, so it's not unheard of.. Just a chance you don't have to take IMHO..
Old 02-22-2010, 08:20 PM
I was just going to say maybe I could scavenge a late model vette tranny but then I remembered fbodies aren't privelaged enough to have transaxles
Old 02-22-2010, 08:31 PM
85MikeTPI's Avatar
The cases are exchangable. D&D will sell you a brand new case with the port for $600... ;-)
Here's a pic:
http://www.eecis.udel.edu/~davis/z28...684_large.html
Old 02-22-2010, 09:02 PM
Oh geez I don't even have 50 dollars to my name as of now, damned college. Maybe ill look for a used one, thanks a lot.
Quick Reply: T56 Temperature Gauge
