Boot Retainer Broke - Any aftermarket Fix?
I epoxied a piece of wire over the break and it's been holding it together for 5 years.
Redline Accessories sells a wire version that won't break if you don't want to fix the old one.
Unfortunately I just got the car and nothing came with the boot. Maybe Ill grab the remaining peices from the sixer.
The one from the sixer has multiple breaks.. What should I do with the wire??
Just checked redline and it seems they only sell boots, not the retainers.
Scroll to the bottom of the page.
If you want to fix yours, I cut a fairly stiff piece of wire about 2 inches long, if you look at the retainer it's cross section is kind of like an L shape, shape the wire and lay it inside the L so it extends on both sides of the break and cover with epoxy.
