clutch kit
Old 06-18-2010, 12:52 AM
TPI TERROR's Avatar
Default clutch kit
a while back i posted a thread based on shifting problems after 3k
https://ls1tech.com/forums/manual-tr...n-problem.html
well today i was underneath the car and i am seeing the leak spreading troughout my oil pan.
its a 02 ls1 block with a built mn12 tranny
i am running the ls7 clutch kit and im plannin to drop the tranny down to see whats going on .
what clutch can i use while keeping my ls2 clutch . ?
while doing this ill be doing the drill mod and adding the shim plate for the slave cylinder
Old 06-19-2010, 01:54 PM
crainholio's Avatar
LS7 clutch in use here for over a year, very good street manners and holds up to road course conditions without a hitch.
edit: I see from your other post that you're running one also. Any reason you want to switch, or just checking the market?
Old 06-22-2010, 02:01 AM
TPI TERROR's Avatar
noh i was looking at spec clutches.
il be dropping the tranny soon and thinking of re doing the clutch, Ive had the ls7 clutch for about 2 years. perfectly fine but searching the market.
Old 06-22-2010, 05:33 AM
crainholio's Avatar
Check out the RPS carbon twin disc. Carbon friction surfaces instead of organic or sintered metal.
Old 08-30-2010, 02:33 PM
GunnyJ's Avatar
Getting ready to swap out my clutch. Thinking about getting the LS7 clutch kit. Should I be getting the the LS7 flywheel also and whats a good site to purchase the entire set from. I'M also considering the Tick M/C. Thanks
Old 09-01-2010, 01:39 AM
tuzzy's Avatar
i dont know how many people know about diamond clutches, but i just put the stage 2 in my car 2 months ago and i love it. it grabs great, nice light flywheel, no chatter. it comes with everything you need. Jason is extreamly helpful with his kits. any questions or problems he will take care of you. check them out
http://www.diamondclutch.com/
Old 09-02-2010, 12:30 AM
TPI TERROR's Avatar
that looks like a nice kit. never heard of it though.
im still debating on a clutch
Old 09-02-2010, 10:18 AM
Billy M's Avatar
We could set you up with a clutch and were only 20 mins from you. Give me a call if your intrested.
Old 09-02-2010, 11:21 AM
TDP
TDP's Avatar
I've got clutch kits starting at $370 for a Stage 1, $410 Stage 2 and $450 Stage 3. Its $350 extra if you want a billet flywheel and slave cylinder included. Diamond Clutch
Old 09-02-2010, 01:09 PM
SPEC-01's Avatar
You could also give me a shout since you were thinking of one of our kits. I would be happy to assist you and I am sure that we could provide a kit that fits your needs perfectly. Let me know. Thanks,
Old 09-02-2010, 06:09 PM
01SS99red's Avatar
Im currently running the LS7 setup and I would never do it again ,its to heavy and not great for track use. +1 for diamond clutches tho.
Old 09-04-2010, 11:29 PM
GunnyJ's Avatar
Which is better, srung or unsprung pp. Also has anyone tried the F1 DFX clutch? The more I search the more difficult it gets to decide. The diamond clutch sounds pretty good.
I have a 02 trans am 50k miles.
Old 09-05-2010, 09:28 AM
crainholio's Avatar
Depends on your priorities.
Unsprung hubs are more durable, but can be obnoxious in street conditions where you're engaging and disengaging the clutch frequently.
You don't notice how nice damper springs are until you drive a car without them.
Old 09-07-2010, 06:14 PM
GunnyJ's Avatar
does anyone have the F1 DFX kit?
Old 09-10-2010, 02:52 AM
TPI TERROR's Avatar
you guys all have deals.. anyways i can keep my ls2 flywheel with a clutch of your guys kits?
Old 09-10-2010, 02:59 AM
TPI TERROR's Avatar
pm sent to the vendors thanks
Quick Reply: clutch kit
