Beware if you buy a Textralia Twin Disk
Not only did I get screwed on a used Textralia twin disk from RedHatRdRacer (click on link in sig) but I had a problem with a brand new one too.
If you buy one, make sure the bolts that are on the back of the flywheel don't hit anything. You would think for $1300 you would get a clutch that just bolts on, but I had to tear car apart again because I didn't bother checking clearances and had to replace bolts on back side of flywheel with bolts that had thinner heads
Also don't use arp fly wheel bolts on the dual disks. Use only stock gm bolts, they will take out the rivits on the inner disk and you might nit be able to get the bolts off because there is no bolt head. FYI for anyone else.
My ARP's clear my Exedy twin and there is nothing hanging off the back of the flywheel for clearance issues. I'm really glad I picked the Exedy but I really only did because I got dirt cheap. I bought two of them and made one good one for less than 200 total.
Glad you finally got everything worked out on the clutch. A journey I know all to well lol
That's strange, My friend had the same clutch with no issues...I bought the clutch off of him and I was going to install it next week. So the bolts that hole the stubs on are sticking out to much and you had to grind down the heads?
No problem, just trying to make sure others don't go through all the **** I had to.
