anything better then the spec 3+ in same price range?
its time to replace my spec 3+ so tuesday i am ordering a new clutch, i love how street friendly this clutch is and it lasted 5k of heavy strip use but while i have the tranny out i am changing it, so my question is, is there anything else out there that will out perform and out last it while still having the street friendliness and in the same price range? i know twin disk can but they are way out of my budget, so please keep suggestions to single disk only. my car weighs 2680 , it makes 545 ft ibs to the wheels (will turn it up some day) and it is daily driven and raced every weekend. i know the spec 3+ was over kill but i like the buffer a little over kill provides, some times i have to make another pass at the track with little cool down time so a clutch thats on the edge of my power might slip if still hot.
I would look into the Monster stg 3 setup. Ive been running one on my SS for a little while now and it loves a good beating and hot lapping at the track. I bought it with there 28lb flywheel and slave/piolet bearing for around 799.00 I believe. But I know sponsers on here run specials.
Well from what I gather I know there is people with 20k or more on them and still ticking strong. My car isnt a DD but does come out almost every weekend and has around 3k or so on it and some track time. Drives nice and doesnt chatter nearly as bad as my spec 3 did. Very nice piece IMHO.
Our Monster Level 3 is perfect for your application. At this point we have several happy customers with 25K+ miles on these units. Give us a call if you have any questions or would like to place an order.
Matt
817-750-2000
Matt
817-750-2000
LS1Tech Premium Sponsor
I'd agree with the above about the Monster! When you add the price of a new flywheel to a SPEC or RAM, the Monster is actually very competitively priced! We've had alot of success with the Monster line-up so far!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
I am one of those customers who had well over 20K on my level 3 Monster when it came out. I had a rear main leak evidently, and it was still holding with no problem. I rarely take the car out without beating on it, and it made several visits to the track. Plus their customer service and warranty is the best out there.
Max, I am convinced that you need one of two things...a drink or a hobby that helps you relax...take a few good deep breaths and think of a happy place (LOL)! I am sure you know that I am just joking with you.
It seems that the OP is happy with the results of the 3+, he is merely looking at other options. I can understand someone being interested in seeing what else is available, even if they were more than happy with what they already have.
Lavoy, If you decide that you want to go the route of another Stage 3+ just let me know and I will be happy to assist you. Thanks!
thanks jeremy, i ended up getting a monster to try out, the spec actually still looks great it only had 5k miles on it and is no where near worn out, it turns out my clutch rod had just came out of adjustment but of course i didnt notice this until i climbed under the dash to adjust it for the monsters different throw so i will either keep it as a back up or maybe pass it along to some one else who cant afford a new clutch. todays lesson is check your clutch rod and master/slave before dropping coin on a new clutch lol.
