Expensive Clutch M/C alternative
I am looking for someone who has one of the 'expensive' $300+ Tilton based master cylinders that is not hooked up. I am looking for the outlet port bore size and the diameter of the fitting that screws into the M/C. Using the shank of a drill bit is probably the easiest way to measure the bore.
Thanks
If you happen to be in the Houston / Pearland, Texas area PM me.
Thanks
My understanding is that "basicly" they use an off the shelf 7/8 bore M/C, add a bit of machining and a -4 AN outlet fitting and hose. The off the shelf outlet bore diameter should be 7/64 which is -3AN. I'm wondering if the 'expensive' unit has the outlet bore increased to 5/32, -4 AN. Also, has the body has been machined for a larger outlet fitting or is the bore of the standard fitting oversized.
I need the standard 90 degree mount and a $4 heim joint, so the other mods don't matter to me. I just don't want to spend an extra $250 if I can do the same thing in my shop.
LS1TECH Sponsor
We have track tested, researched and improved our kits multiple times over the course of our tenure in the LSx Market. The T56 Transmission (and it's workings) are our specialty - we eat, sleep and breathe these things. Our kits are hands down the quickest shifting and most reliable units on the market, and although many have tried (and failed) to duplicate us - you simply can't beat the originator in this case.
I dont think its really right to say he's trying to rip you off. From the sounds of it, he's not trying to sell them to make a buck, he just wants to build his own. I'm sure everyone is aware of your M/C and their benefits by now and if he chooses to not buy one from you, so be it.
LS1TECH Sponsor
Hi Joey, I am not looking to start anything here and I am not trying to rip anybody off.
I have a Wilwood m/c with the outlet bore, line and both fittings at 4AN for my T56. When I contacted you last week, I stated this. When Jonathan replied that your m/c used a 4 AN fitting too, I would have had to be brain dead not to question why. The requests above are simply me trying to satisfy my curiosity. I have no intention of trying to be 2QWK II.
