T5 5 Speed
Old 07-29-2010, 09:46 PM
Quick99TransAm's Avatar
Default T5 5 Speed
can i swap a t5 into my 99 T/A 6.0 swap.what all do i need if so
Old 07-30-2010, 08:26 AM
thesource's Avatar
Why would you want to?
Old 07-30-2010, 12:15 PM
Default tranny
I dunno why not
Old 07-30-2010, 12:35 PM
oifish's Avatar
Do you think a T5 would hold up to the power your 6.0 would be putting down? My knowledge is limited when it comes to the T5, but I think you would be better off opting for a T56. Much stronger, better aftermarket support as well.
Old 08-01-2010, 06:30 PM
N20zuki's Avatar
a WC T5 is rated at 300ft/lb and a NONWC is 250ft/lbs... A T56 is rated at 450ft/lbs, so being people grenade a stock T56 behind stock LS1 motors and stock 305 TPI can grenade a T5. Why would you want to use that transmission that would shatter behind even a 4.8, save money and use a T56 or TKO if you want a manual.
Old 08-06-2010, 07:16 PM
lm7rs's Avatar
oifish and N20suki have very valid points t-5's cannot handle alot of torque i've already broken one on my t-5 but i would still like to know if this can be done i have a t-5 now and cant really afford a t 56 and would like to keep it atleast to drive the car while i save up for the t56 can it be done? on a 5.3
