Transmisson Fluid
It's just shy of 4, I also would recommend since you are going to be taking the trans out to replace the pilot bearing and slave cylinder (seeing how that might break when you drop the trans from the car). Those two things are hardly an expense when you have already got the trans out but will save you trouble in the future.
Yes you can use Mobil 1 synthetic ATF. Buy 4 quarts. Like said, it's just a little less than that. After I drain the tranny, I take the shifter off, stick a funnel in the hole, make sure the fill hole is open, and then pour all 4 quarts down the funnel. Then I close the fill hole once the stream of extra coming out slows down.
You can use Dexron III, Mobil 1 ATF, or Pennzoil Syncromesh, none of them will hurt the transmission and they will all work. Just don't use Dexron VI or Royal Purple tranny fluid. They can do bad things.
My vote is for Mobil 1 atf, you need 4 quart, I did try plain jane dex/mercon not happy , pennzoil syncromesh not happy, mobil 1 atf ( very happy ), I also want to try redline D4 and AMSOIL torque drive, mabe next year.
ANY ONE HERE USING MOBIL 1 ATF AND HAVE ATF SMELL INSIDE THE CAR ? it been over a month and I some time still smell it lol.
Killagt why do you want to keep changing brands if you have found something your happy with? What did you not like about the other brands? Would it be safe to assume that you have checked for any tranny leaks?
when I try pennzoil syncromesh, it shift bad when first thing in the morning, until 10 min later it shift good, fluid never break down when long hard drive, but I have feeling that the most wear happent is first time drive, if fluid have to wait for 10 min drive to warm it up then start protect, then those first 10 min is wear my tranny out.
and I try mobil 1, bam !!! best of both word, fluid never break down when hot or long drive, shift good in the morning and when it heat up. and beside mobil 1 atf is synthetic high quality, so that also give me a peice of mind that im running quality fluid, that mean give me good protection heheh.
redline, I been using it for year on other car, alway want to try on my camaro, i just dont have time to wait for it to on in the mail. Redline is high quality then mobil 1. I want run best of the best, but for now mobil 1 is fine for me.
Do you have atf smell inside your car, after put in mobil 1 atf, mabe after it get hot, it have smell ?, the fluid is exelent, high quality, just the atf smell something, mabe I smell it cause the fluid still have under 500 miles on it hehe.
I kept on hearing about people screwing up their blocker rings because of synthetic ATF. I checked with Tremec, who told me to stay with Mobil 1, and then after I had some issues with my tranny (turned out to be nothing ), the mechanic I delt with (who actually knew his stuff) told me I had the paper blocker rings, which like conventional fluid.
I switched from Mobil 1 to Citgo and haven't really had any issues with either. The Mobil 1 seemed to shift a bit easier, but the Citgo made some noise go away. No real big issues, it was more of a preventive maintenance step.
I've heard that paper rings work off of friction, and synthetic fluid doesn't provide enough friction to keep your rings working as long as they should. I probably will change fluid once a year or so (with a pump, it's not a bad job), so I'm not too worried about breakdown.
I changed mine out and had some O"reillys brand DEXIII and used it. I thought about using the Pennzoil synchromesh. However, I just went with what was on the side of the transmission. No grinding or hard shifting when its cold. Everything seems fine.
that wat i use before, oreilly is not that high quality fluid, give me grind second when hot, and not doing well when high rpm, switch to mobil 1 atf, and fix all problem , just the atf smell inside car when fluid getting really hot
