M6, Tranny Problems :(
Old 10-07-2010, 07:18 PM
02ChevSS's Avatar
Default M6, Tranny Problems :(
My shifter is gettin stuck on fourth. Makes a grinding noise. The only way to get it out is to let off the clutch pedal a little. Its drivable, but it gets stuck every once in a while. I reacently changed my clutch, slave, master, pilot bearing. I now have a Ls7 CLutch.
Attached Thumbnails M6, Tranny Problems :(-imagescae191l3.jpg
Old 10-07-2010, 07:25 PM
TransAm Bandit's Avatar
i Have The same Problem in 2nd Gear
I might go with New of rebuilt t56
Old 10-07-2010, 09:03 PM
_JB_'s Avatar
LS1Tech 20 Year Member
Mine would get stuck in fourth, but never grind. I eventually had to do a rebuild.
Old 10-07-2010, 10:59 PM
02ChevSS's Avatar
I was afraid of that.
Old 10-08-2010, 02:32 AM
TDP
TDP's Avatar
Chances are the synchro keys are in the process of breaking, or are broken. This will cause the sleeve/hub to bind and stick in gear. A rebuild is inevitable in both of the above-mentioned transmissions.
Old 10-08-2010, 07:46 PM
LS123's Avatar
I agree. It is always broken synchro keys!!! I would advise rebuilding ASAP! I have seen cluster gear distroyed because the magnet didn't catch the keys.
Old 10-09-2010, 12:12 PM
02ChevSS's Avatar
Thanks everyone, im going to drop it tomorrow and get to work.
Old 10-17-2010, 03:25 PM
02ChevSS's Avatar
It ended up being 1-2 bilet keys. Im going to replace 3-4, also. Thanks.
