1995 Z28 Clutch Advice Needed
Hey guys been reading this forum since I was 15, and I've been through 4 camaro's since then.
I'm on my current 95 z28, and she is mainly stock with, 4.10 gears, and a 125 wet shot. I kept the tiny street tires to save my stock clutch and 10 bolt, until i can afford a strange 12 bolt after deployment.
But after blowing the doors off a 2005+ mustang that was antagonizing the sh$% out of me, I roasted my clutch in 4th gear. It started slipping and now slips while cruising in a high gear if I give it any gas.
Everyone and there mom has a recommendation on which clutch i should get. I've heard centerforces are good with nitrous because they increase grip with rpm ??? Also heard the Mcleod RST twin is a good set up for a weekend warrior.
I want dd clutch with plenty of holding power for highway runs on the bottle, and launches with some sticky street tires.
any advice would be appreciatted.
thanks in advance
thanks in advance
all my mods are in my sig. all i have done is put in a ls7 clutch package from ebay. 389.00 shipped to my house. if i am right i believe it is a 640 pd tq clutch. i got the flywheel and clutch for that price... and put in a new slave cylinder. definately put in a new one when you put the new clutch in. it will save you time and alot of headache..
LT1s use the pull-style pressure plate, which is reverse of almost every other type of clutch. Go to this website www.diamondclutch.com and look at the 3 Basic kits that I offer. I can sell you an LT1 version of any of them for $439. However, I just don't stock the flywheel for the LT1. Let me know.
We offer our Super Street Pro Kit 75216 that comes with P/P,Bearing,Disc,Pilot Bearing and Pilot tool. We also offer a billet steel and aluminum flywheel. Give me a call if you have any questions.
We offer 7 different stages for this application and the most commonly purchased part for high-torque and aggressive use for those seeking daily driver characteristics would be our Stage 3+. It will provide great drivability and plenty of capacity for your needs and the kit is complete with a full-faced carbon-graphite disc, high-clamp pressure-plate, TOB and Pilot bearing as well as the alignment tool. We also offer steel and aluminum flywheels too. I provided a link that you may be interested in as well. Take a look and let me know if you have any further questions. Thanks!
https://ls1tech.com/forums/manual-tr...-question.html
