shifting at WOT
Old 12-20-2010, 07:30 AM
TA_BUD's Avatar
Default shifting at WOT
ok here it goes, ive done drill mod, clutch m/c mod, and adjustable rod, new stock clutch and flywheel, and slave, when giving all its got when racing should it grind when switching gears
Old 12-20-2010, 08:36 AM
85MikeTPI's Avatar
There's dozens of variables.. The TICK master might help, a stronger clutch might help, a rebuild with new synchros might help, ad-nauseum.
Old 12-20-2010, 08:53 AM
TA_BUD's Avatar
i have a great clutch pedal, no slippage of the clutch
Old 12-20-2010, 09:47 AM
SMOKNSS's Avatar
With a stock clutch you SHOULDN'T have any problems... as long as your clutch fluid is clean, there are no air pockets and your trans is in decent shape. The only problems I have ever encountered have been when you upgrade to an aftermarket clutch. Stock clutches shift like butter if everything else is good.
Old 12-22-2010, 11:54 AM
TA_BUD's Avatar
come on guys give me more imput, is this normal?
Old 12-22-2010, 12:01 PM
jmd
jmd's Avatar
Nope.
All gears? Your clutch may not be releasing properly. Did you measure and use a spacer beneath the slave accordingly?
Consistently happens going into specific gears only? Time to refresh the trans. like Mike said.
Old 12-22-2010, 12:20 PM
TA_BUD's Avatar
Originally Posted by jmd
Nope.
tranny only has 62,xxx miles on it, not sure what you mean about a spacer, please help
Old 12-22-2010, 04:46 PM
jmd
jmd's Avatar
A push style clutch release bearing has a distance spec. it needs to be away from the pressure plate fingers.
A pressure plate's fingers can change position based on disc wear (plate gets closer to the flywheel, fingers go out) or when the flywheel is machined (PP becomes closer to the engine) and not every PP is the same.
In your case with stock parts, this wouldn't tend to be a concern. So is it specific gears?
Old 12-22-2010, 05:00 PM
TA_BUD's Avatar
shifts real good, 1-4 gears when racing, slight grind when shifting
Old 12-22-2010, 07:52 PM
gnx7's Avatar
make sure you have a heat sleeve on the braided clutch line and keep it well away from the headers.
Old 12-22-2010, 08:16 PM
pitbull14218's Avatar
Mine does this... I'm about to get a rebuild.
Old 12-22-2010, 09:55 PM
VindicatedLS2gto's Avatar
Synchros....
Old 01-03-2011, 07:57 AM
TA_BUD's Avatar
wow i cant believe i really havent got a good answer yet
Old 01-03-2011, 08:04 AM
tording99Z28's Avatar
A few people have said rebuild with syncros. The syncros are what allow the gears to line up when you push the clutch in and after miles of hard shifts and wear they grind down and wear out plus I believe in the Fbodys T56 they are plastic so they wear even faster. Time for some new sycnros at least probably.
Quick Reply: shifting at WOT
