Tr-6060 ?
Old 03-09-2011, 06:57 AM
96 lss-10's Avatar
Default Tr-6060 ?
I have a tr 6060 out of 2010 Camaro SS. I am replacing the main shaft (sheared off at the tailshaft) and the main case (it has a hole in it from the dealership). Has anyone dealt with this trans much. I am wondering if I can use a different yoke than what is on it from the factory.
Old 03-09-2011, 08:45 AM
85MikeTPI's Avatar
There's no yoke on it, just a bolted flange. Are you trying to put it into another vehicle? If so, you might just want to send it to RPM to have it converted with a standard slip-yoke tailhousing, mainshaft, shifter, mainshaft...
Old 03-09-2011, 09:10 PM
96 lss-10's Avatar
It is going into my s-10. I was wondering if there is a slip yoke for it. I just bought my mainshaft for it.
Old 03-10-2011, 06:58 AM
85MikeTPI's Avatar
No.. If you have the mainshaft, you should be able to see the flange splines and bolt threads.
Old 03-10-2011, 06:57 PM
96 lss-10's Avatar
It is splined, I just dont know how many.
Old 03-10-2011, 09:34 PM
jmd
jmd's Avatar
What mainshaft or PN mainshaft did you buy?
Old 03-11-2011, 04:25 AM
Sargeant Sh!tbag's Avatar
I think you should stick to this suggestion..
RPM does amazing work in a timely manner. They can do anything you want.
Quick Reply: Tr-6060 ?
