LS6 clutch question, Newbie needs opinion.
Old 04-08-2011, 11:03 AM
VoggsZ28's Avatar
Exclamation LS6 clutch question, Newbie needs opinion.
I am converting my 2002 Z28 from A4 to M6. I have all nessecary parts and job is underway. I purchased a GMPP LS6 clutch setup, but do i need to change or upgrade the 00-02 slave and throwout to a GMPP one??? Summit racing states the upgrade must be done. Anyone do this, or run into this? If so what did u do??
Old 04-08-2011, 12:59 PM
VoggsZ28's Avatar
Exclamation
Anyone??????
Old 04-13-2011, 03:50 PM
AiDRocks's Avatar
Someone help us. I need a new clutch as well and like to know.
Old 04-13-2011, 04:24 PM
Sargeant Sh!tbag's Avatar
I guess the first question would be.. Why do you want to go with the LS6 clutch??
Old 04-13-2011, 07:24 PM
BandDirector Blk98ZM6's Avatar
I went with an LS6 clutch back in '04 when I did my LS6 longblock swap in my '98 Z28. I DID update to the newer slave, but used my old master cylinder...
Old 04-13-2011, 11:59 PM
I dont think you need the GMPP slave.. From what I have been reading in my searches here to try and help you it appears people are simply installing the clutch with no issues on 01 up cars.. I would just replace the slave anyways while you are in there.
Old 04-14-2011, 01:14 AM
NVR_SPDS's Avatar
The LS6 clutch came stock in the 01-02 F-bodies. There is no NEED to update the hydraulics, but it is a good idea to take care of it while its apart.
Old 04-17-2011, 02:19 PM
VoggsZ28's Avatar
Thanks for the info guys, and not all 01-02 came with LS6 clutches, upon checking part numbers 731 or 806, the clutch that came from the 02 donor z28 (saw car and VIN) was a 731. With my setup, a full bolt on car, and also making car retain factory look and feel, the LS6 is a no brainer. Happy to say that i completed the swap from auto to M6 with no issues. 7 hrs total, and for those with probs with how to wire the reverse lock out......just wire hot to solenoid and attach ground to the p brake ground side switch. when you want reverse pull the p brake up 1 click. solves a4 to m6 harness wiring probs.
Old 04-17-2011, 02:24 PM
VoggsZ28's Avatar
also used factory slave, no probs, but recommend bleeding master prior to plugging into slave for final bleeding, you'll save 30 mins of frustration.
thanks again guys.
Quick Reply: LS6 clutch question, Newbie needs opinion.
