Kinda popping out of 3rd
Old 07-04-2011, 02:23 PM
rob69zombie's Avatar
Default Kinda popping out of 3rd
My 2000 SS m6 is lightly popping out of third gear if I release the lever before I let the clutch out. It doesn't take more force than the weight of my hand to keep it in 3rd and after I release the clutch I can let go of the lever and it stays in just fine. Also, once it's in and good, I can (without touching the shifter) accelerate or maintain the same speed, push the clutch in and out several times and it does just fine. It stays in gear perfectly. Does this sound like I'm going to have to open the case?
Old 07-04-2011, 02:27 PM
Oh yeah, it allows me to speed shift into 3rd at wot just fine.
Old 07-04-2011, 02:59 PM
DAVESS02's Avatar
Yea, you'll have to open it up but as long as it hasnt been grinding you might get by with some minor parts like fork pads.
Old 07-06-2011, 12:36 PM
Is there any possibility that this clutch may be not fully engaging all the way? Or could this be a hydraulic problem of some kind? It BARELY does it and sometimes if I release the clutch very slowly, it does just fine; even when my hand isn't on the shifter holding it. I'm going to change the clutch out anyway to an LS7, but I don't want to put it back together more than once if it's just going to do the same thing with a new clutch and hydraulics. It doesn't do it in any other gear, so that points to the internals of the trans; on the other hand, I was thinking that maybe the combination of the lever placement (stock Hurst w/ short stick) and a faulty clutch would make it do it. Any thoughts?
Old 07-06-2011, 09:30 PM
calhoon's Avatar
It is doubtful this is a clutch issue. If you have the original aluminum 3/4 shift fork....thats the prob. Do a search.
Old 07-06-2011, 09:38 PM
No, thanks. I'm having it rebuilt next week. Thanks for the input.
Old 07-09-2011, 01:43 PM
busa317's Avatar
hey man i have a 02 ss and i have the same exact problem this just started last week just wondering if you figured anything out and if your getting it re -built where are you getting it rebuilt at $$$$
Old 07-09-2011, 02:09 PM
ws6outlaw's Avatar
3rd gear synchronization going bad?
Old 07-09-2011, 03:54 PM
busa317's Avatar
thinking it can be a shift fork problem
Quick Reply: Kinda popping out of 3rd
