How bad really is power shifting? T56
Old 09-22-2011, 08:37 PM
Raoul-Duke's Avatar
Default How bad really is power shifting? T56
Sums it up guys, How bad is it really? Also when should you change clutch fluid?
Old 09-22-2011, 09:12 PM
kingd_202's Avatar
I did it my ta and no problem, I change the fluid every two weeks in it...
Old 09-22-2011, 09:56 PM
WeakSauce6's Avatar
Depends on the driver. Is it good for the transmission? No, but if done right it won't make a huge difference over the life of the transmission.
Old 09-22-2011, 11:11 PM
DAVESS02's Avatar
IMO, the biggest thing is having a clutch that fully disengages. Anything that has a history of a spongy pedal or occasional sicking is a disaster in the making.
Old 09-22-2011, 11:47 PM
Nmbr1GMfan's Avatar
Third gear is going to be your issue.
Old 09-23-2011, 10:26 AM
LS1TECH Sponsor
Joey@Tick's Avatar
Power-shifting with a properly functioning clutch & hydraulic system is abuse, no question, but power-shifting with a clutch that isn't fully disengaging could be disastrous. Once you've got a quality master cylinder and a clutch/slave that is up to the task, power-shifting is the only way to go. You simply leave too much speed on the table by not doing it. Check out a few videos of our customers power-shifting using our Adjustable Master Cylinder Kit here: http://www.tickperformance.com/tick-...or-ls1-f-body/
Old 09-23-2011, 07:47 PM
Raoul-Duke's Avatar
You change the fluid every two weeks??!!! Is that normal? damn how do you get it out?
Sounds good, I started a little but stopped because I don't wanna deal with problems down the road. Also how bad is downshifting to third on the highway at 80mph with stock 3.42 gears. I used to do it quite a bit but stopped as well
Old 09-24-2011, 09:09 PM
flintwrench69's Avatar
Just open the bleeder on the clutch slave(need a 7/16 socket & ratchet for the bleeder), let all the fluid drain out of the reservoir. Then you can wipe out the reservoir with a rag as theres usually some black stuff in there. Then continue to add brake fluid to the clutch reservoir until a small 12 oz bottle of brake fluid is empty. That should get most of the old fluid out of the system. I recommend using dot 4 fluid as it has a higher boiling point. Changing it every 2 weeks is too often. Even once a year is too often but if you track the car a lot it isnt a bad idea. If your clutch fluid keeps turning black your master cyl is on its way out.
I would be more concerned about changing the trans fluid if I was powershifting the car a lot.
Very true. Thats why I highly recommend getting a Tick master if you plan on powershifting.
If everything else is in good shape(clutch & hydraulics) the shifter is the biggest factor IMO. Missing 3rd is the most notoriously missed gear but my 5.0 shifter hits it pretty good. I heard the MGW does too.
Old 09-26-2011, 06:20 PM
Raoul-Duke's Avatar
Im sorry for the bother but where can I find the clutch slave at? I really appreciate it man.
Also thats good to know because I have changed the trans with mobil 1 synthetic about 15k ago
Old 09-26-2011, 08:14 PM
The clutch slave is inside the trans bellhousing. The bleeder screw is just above the clutch line recessed in a small opening in the trans.
Old 09-26-2011, 08:16 PM
NHRATRANSAM64's Avatar
The slave is located at the 10 o'clock position on the bellhousing, if you were looking directly at your flywheel from under the car.
There is a 1" x 1" window where the bleeder screw is recessed about 1/4" into the bellhousing. make sure you dont drop the socket into the bellhousing, before I purchased the tick master and speedbleeder, I taped the socket on the extension very well before bleeding.
If you ever need to change the slave, buy TICKS speedbleeder. It makes changing the clutch fluid a 5 min, one man job.
Old 09-27-2011, 06:43 AM
blu byu EH's Avatar
^^Do what this guy said. Do it now why you can and able too!!!
Old 09-27-2011, 08:37 PM
Raoul-Duke's Avatar
Thanks a bunch guys, also how often should I change the clutch fluid and what are the outcomes of not doing it? The car has 73k on it. I bought it with 50k and never did it
Old 09-27-2011, 09:48 PM
blu byu EH's Avatar
I change it when it's black or getting black.
Quick Reply: How bad really is power shifting? T56
