can you mix tranny fluid?
a year ago i had my 1998 t56 at the dealer for some tranny work........they replaced it with new fluid not sure if it was dexron 3 or syncromesh......im in the middle of installing my s60 and a new racetronixpump......with the driveshaft and rear out of the car, i started my car to see if the new pump was workingbefore i put the rear in.........i let it idle for a bit and a good amount of fluid came out of the rear of the trans where the driveshaft is....so id like to throw just a little fluid in it......but again, not sure if they used dexron 3 or syncromesh......if im only adding id say 4-8oz, can i throw either in?
