Issue with 2nd gear...
Old 11-09-2011, 05:24 PM
Super-Bat's Avatar
Default Issue with 2nd gear...
Noticed last weekend that while in the parking lot I had the car in 2nd (left it that way when I parked) and when I went to shift, it was in Neutral.
Kind of a WTF moment, I put it back in 2nd and watched as it slowly moved itself out of gear and back into Neutral.
Thinking back a few days, it explained why when pulling out of the parking I could've sworn I put it in gear and then as I gave it gas, I was free-revving.
So it seems 2nd gear likes to move itself out, but only sometimes. If I leave my hand on the shifter it doesn't fight with me, it stays in place. It doesn't pop out of gear once I start accelerating either, only if the clutch is still in.
Thoughts on what it could be?
Old 11-11-2011, 01:22 PM
Super-Bat's Avatar
Bueller?
Old 11-11-2011, 01:53 PM
85MikeTPI's Avatar
It's either not fully engaging (shift fork pads, shifter stop, shifter cup) or it's not being held in place (synchro keys/springs).
If you don't find anything by inspecting any shifter stops and shifter offset lever cup, it's time to open up the trans and see for sure.
Old 11-11-2011, 06:15 PM
Super-Bat's Avatar
Hm... care to dumb it down a bit for me? Not too savvy on transmission internals.
Where should I start looking first and what am I looking for?
Old 11-14-2011, 09:38 AM
bjamick's Avatar
Your T56 is most likely in need of a rebuild. Mine does this same thing. Except it does it in 3rd and 4th now. Also grinding to.
Old 11-14-2011, 09:54 AM
thesource's Avatar
Probably worn fork pads but could also be something like a tapered slider and gear too. Basically the only way to determine what is wrong with it is to open it up and have a look. Thats going to require it to be removed and disassembled completely.
Old 11-14-2011, 09:59 AM
Super-Bat's Avatar
Bah. More money.
Is this something that is time sensitive? There isn't grinding (gotta find some wood to knock on since now it'll probably start grinding today) at any point.
I guess what I'm saying is, in it's current condition, is it hurting anything or is it just more of an inconvenience kind of thing?
Old 11-14-2011, 10:12 AM
thesource's Avatar
If the pads are worn, eventually its going to wear out the actual fork itself and could lead to other issues with 2nd gear because it will no longer be applied far enough into gear which will lead to damaging the gear and slider.
Old 11-14-2011, 11:40 AM
85MikeTPI's Avatar
Cheapest/easiest things would be to pull the shifter off and inspect the small cup in the offset lever where the shifter "ball" engages the lever. Also, if you have an aftermarket shifter, check and make sure any stop screws are backed all the way out or just remove them completely.
If neither of these pan out, then you're in for a rebuild..
Old 11-14-2011, 11:43 AM
Super-Bat's Avatar
I recently (couple months) installed a Hurst billet/plus shifter.
What would be wrong with the cup? Would it be broken?
Old 11-14-2011, 11:55 AM
thesource's Avatar
The cup could be worn or damaged. I doubt that is the issue but its worth a look. I would double check the adjustment of the stops on the shifter if they are present to make sure its not that. I don't remember if that shifter has stops on it or not.
Old 11-14-2011, 01:01 PM
85MikeTPI's Avatar
HURST #391-5061 Billet/Plus Shifter:
"Adjustable positive gear stops to help prevent internal transmission damage"
Old 11-15-2011, 03:28 AM
Super-Bat's Avatar
I looked over the cup when I installed the shifter. There was nothing physically wrong with it that I could tell. Just dirty. I wiped it down prior to putting in the new shifter.
It's actually the Hurst 391-5063 model (I have a 5-speed) but yea, same adjustment points.
Old 11-17-2011, 08:45 PM
Super-Bat's Avatar
So... this passed week... hasn't been doing it.
Quick Reply: Issue with 2nd gear...
