Never EVER Buy A RAM Clutch!
The first one I bought from them I had professionally installed and it failed within two weeks (not slipping, some other mechanical failure) leaving my stranded.
That clutch was replaced under warranty and the replacement clutch would not disengage after being installed. After uninstalling and reinstalling THREE TIMES I finally figured that it couldn't be something I was doing so I measured the clutch and it was too thick, so they sent me another one.
The third one finally was able to disengage, but it was extremely rough on engagement, and after only 8 months and less than 6,000 miles it is already slipping! That is all street driving, no track at all. Mind you the AutoZone clutch that was in before this had almost 30,000 miles and was still holding strong when I decided to replace it with the "better" RAM clutch.
So f*ing pissed right now. F-U-RAM!!!
Thanks for listening to my rant. I feel a little better, but am still extremely unhappy.
So on that note, what clutch would you guys recommend for me? See sig for car details.
Glad your customers haven't had issues, but my experience has been more than frustrating.
Same
Funny...I just bought my first Ram (HDX) after running Centerforce Dual Friction prior with no issues. Now the Ram clutch wont disengage until its damn near on the floor and sometimes grinds gears mainly 3rd & reverse it seems...Centerforce was close to the top on disengagement. Everything I'm running is the same as before with the old clutch with exception of the clucth fork which appears to be the exact same. The TOB rests just shy of the fingers and seems makes contact with fingers correctly, but still wont allow it to disengage until the floor. Extremely frustrated at the thought of pulling everything back apart!!!
I'm running a 383 stroker with a Tremec TKO 5 speed and Lakewood scattershield bellhousing (which I also hear have severe alignment & fitment issues)...all in a 68 Camaro.
Don't sell Ram clutch products but they have always seemed to have a decent reputation. 9 times out of 10, when the clutch fails that quickly either the installation was done wrong, the break in was not done properly or there was an issue with the supporting parts like the hydraulics or clutch cable adjustment depending on the vehicle.
My slave was working fine on my car but when I went to put the twin disc in it recently I couldn't get the trans all the way in. The slave had worn a groove in it which wouldn't let the slave bottom out. The new clutch needed the extra room. My slave only had about 6-7k on it.
yeah installation and proper break in is critical,i should know i have a ram vds rebuildable its been rebuilt twice,mainly cause i had another member from here thought he knew what he was doing (wont mention his name or he will cry), but turns out i had somebody else fix it on the first try and bam its been grabbing great since for a few thousand miles so far.
Think I did everything right but I guess you never know for sure if something little was missed. I'm not new to this and have installed clutches several times without issues though.
Not trying to unduely bash a company either. One-offs happen, but that fact that I had several back-to-back clutch issues that were 100% not my fault and now this one wearing out so quickly, I felt it was worth sharing.
I won't by RAM ever again either, mine went out just over a year, the clutch springs broke and fell into the pressure plate, by luck I took it out in time before it got worse. RAM warranty is only 12Kmi or 1yr. It worked fine the first year then it failed.
I'm sure this does not happen to everyone, I just don't find them reliable.
I dont know , I installed a ram HD in a cam only gto and it fell apart. The springs failed in this one also. But back in 2003 I installed one on my turbo z the hd series. rated at 600 tq. i surpassed the rating by 160 tq. I beat the livin **** outta that clucth. Highway run 1 /4 mile too. Hell I was even able to sell it in 2009. And that guy beat on it at the track. for a year. Im guessing ram may be conhuts with this china ****. I cant see a bad *** cluch taking a nose dive like this. I never slip that cluch with 830 to the wheels and 6th gear highway pulls. Somthing is up.... Ram?
Well the car is going in tomorrow for what is probably its 6 clutch, starting with a ls6, spec 3, spec 3+, ls7, McCleod street twin and now trying a McCleod RXT. I really think that the aftermarket clutches need to be set up properly and that just shimming under the slave is not the answer. Will be looking at either changing the TO bearing to a thinner dimension or maybe having a shim made to go between the bell housing and transmission.
