Will the Corvette skip shift hump fit an F-Body
Old 12-23-2011, 05:32 PM
89ROC-Z's Avatar
Default Will the Corvette skip shift hump fit an F-Body
Will that hump fit the tunnel?
It sticks up about 1.5"...
Old 12-23-2011, 06:28 PM
thesource's Avatar
Remove it and use the plate found on everything but the vette.
Old 12-23-2011, 07:40 PM
jmd
jmd's Avatar
https://ls1tech.com/forums/15691481-post68.html
89ROC-Z's Avatar
In order for me to remove the lever inside, i'd have to pull the trans apart. That lever sticks up above the flat surface of the case
Old 12-23-2011, 07:43 PM
jmd
jmd's Avatar
Did you buy it that way?
Old 12-23-2011, 09:32 PM
thesource's Avatar
So the genius that built it didn't cut the top part of the selector off?
Old 12-23-2011, 09:55 PM
85MikeTPI's Avatar
Yup, and with the amount of rtv oozing from the front plate seam, you might be better off opening up that trans and having it done correctly before you're back posting about shifting problems...
Old 12-24-2011, 10:13 AM
89ROC-Z's Avatar
The trans was built by a reputable shop, i'm not worried about that. I'll dig into my file and see what shop assembled it. So Mike you think i should have it taken down to remove that selector arm?
Old 12-24-2011, 11:34 AM
jmd
jmd's Avatar
No, just bash a big upwards dent in the floor.
Quick Reply: Will the Corvette skip shift hump fit an F-Body
