How to install a B&M shifter?
UPDATE: Issue - post 9
Sorry, but Im tired of sifting through every thread that mentions B&M...
Im installing a clutch tonight along with a B&M shifter. I cant find any documentation on the shifter whatsoever. So I have to ask, which way does it go in and how do I adjust the bolts for the stick throw (and the bolts on the base to the tranny)?
TIA
TIA
The bolts that bolt it to the trans have off set washers. They are off set so you can position the shifter to your liking. IIRC the throw set bolts are not needed on a t56. I remember the instructions saying to back the bolts almost all the way out put the car in 3rd gear and screw the set screw till it barley touches the lever then back it off a turn.
So basically I back the adjustment bolts all the way out, put it in gear and screw in until it hits the shifter (then tighten), correct?
Question though, is it possible that I might over throw the gear? Im guessing not since the adjustment has been said to not be needed...
Thanks so much!
Thanks so much!
