crap! was told i need a Clutch kit...which one?
Old 01-29-2012, 05:37 PM
stroked383HSR's Avatar
Default crap! was told i need a Clutch kit...which one?
ok so i was told my problem is my throw out bearing or PB....and was also told i might as well replace all of it since im going to be in there.
what do i get?
something not high dollar?
thanks
Old 01-29-2012, 07:13 PM
also ...how hard is it to change?
Old 01-30-2012, 12:17 AM
splitfinger09's Avatar
http://www.tickperformance.com/tick-...camaro-firebird/
Not exactly cheap but you get what you pay for. I got the level 2 with the 28# flywheel and the arp bolts.
Old 01-30-2012, 12:20 AM
http://www.installuniversity.com/ins...ch_install.htm
Install looks fairly strait foreword but obviously involves dropping the transmission so that will def be fun haha. And this is all on your back unless you have a lift...
Old 01-30-2012, 07:41 AM
R Myers's Avatar
Default Clutch
I just orderd a GM LS7 kit from tick http://www.tickperformance.com/gm-ls...-applications/ good price to they have every thing you will need.
Old 01-30-2012, 07:51 AM
Captain Double Post
BOBS99SS's Avatar
the ls7 is a good cheap clutch for getting around, if its going to see a ton of abust though i would go with something better such as a monster or something
Old 01-30-2012, 12:23 PM
SIC GTO's Avatar
Monster!
Old 01-30-2012, 03:23 PM
SPEC-01's Avatar
If you are looking for a great option that provides better than stock capacity and fantastic drivability then I suggest our Stage 1 kit. It can be used with a stock (resurfaced) flywheel as long as it is being cut for the first time. Or you can opt for one of our flywheels, available in billet steel or billet aluminum. Take a look at the link below and let me know if you have any further questions. Thanks!
http://www.specclutch.com/cars/Chevy/Camaro/1999/Single
Old 01-30-2012, 10:24 PM
actually I was told it was the TO bearing.....but was also told i shouldnt just replace that.
I was looking a the ZOOM stage 1 kit they sell at Advance for $359.00 comes with everything including the TO bearing/slave cylinder also.
any body have experience with that set?
Old 02-01-2012, 08:55 PM
so what causes a TO bearing and or slave cylinder to go bad?
Old 02-01-2012, 10:54 PM
VandykeT/A's Avatar
The slave/to bearing is made together. The TO bearing is just like any other bearing they just wear out over time and if the slave part fails it will leak and you'll lose your clutch. Dropping a tranny in these things aren't any more difficult than any other rwd car. I wouldn't mess with zoom if you have or plan to mod any. I've always used RAM clutches and have never had problems. Most guys will tell you monster and another is TDPs clutches. When one of my powergrips shoot their wad I'll be using a monster or one of TDPs. My only advice on pulling the tranny is get it as high as you possibly can and a friend always helps. Check youtube I think theres a how to. GL
Old 02-01-2012, 11:51 PM
Stryker's Avatar
If u have a jack and 4 jack stands pulling a t56 is easy. One of the lighter trans to " man handle". But if your going to pull is say go with spec. They are the best bang for buck ls clutch and they are great on the technical side if u have issues or questions. Gm pilot bearing and slave are fine but it would be a good time to upgrade to a tick master cyl. Just get your wallet ready.....
Old 02-03-2012, 11:35 AM
00ws6indubv's Avatar
I have a the diamond clutch stage 2 from Jason at TDP and a tick master take a look at those. Very good clutch, and the tick master makes shifter so much better. The T56 weighs somewhere around 115lbs so take for what you may. Me and a friend did my clutch and master install. If its your first one be ready. its only easy to people have have did a few. It will take some time and make sure you have a LONG LONG extension for the upper bolts on trans, and also maybe a swivel head for your sockets. Just take your time be patient. Buy a tick remote speed bleeder Best 50 bucks you will ever spend took us literally 5 mintues to bleed after install. Plus leave it zipped tied off in your engine bay and if you ever need to rebleed system down the road its right there. But like stated above looks at how tos on this and there are plenty of other tips out there for ya good luck!
Old 02-04-2012, 01:20 AM
therealcreeper's Avatar
this is my zoom/perfection clutch after 5k miles
and the slave cylinder crapped out 10k miles after I swapped the clutch
summary: don't buy anything clutch related from advance/perfection/zoom
Old 02-04-2012, 02:29 AM
PACKERSz28Camaro's Avatar
Go with the stock Z06, LUK replacement clutch. 04173 is the part number I think. Really inexpensive
Old 02-04-2012, 04:25 AM
firebird99's Avatar
Best clutch for the money for a dd that doesnt go to the track every week.Ive had mine in for two years put 40,000 miles on it and it still looked almost new when i pulled the tranny out in last august.Now i dont take it to the track but i do beat it everyday with a cam and bolt ons so it doesnt have a easy life fwiw.
Old 02-04-2012, 07:12 AM
Captain Double Post
BOBS99SS's Avatar
last time i saw the ws6.store was selling the ls7 kit really cheap
Old 02-04-2012, 11:17 PM
HOLY CRAP! well that answers my question about zooms
where can i have a look at that?
Old 02-05-2012, 10:54 AM
98z-28redcamaro's Avatar
i have had my zoom clutch a while...and its been in for 40,000 miles and a lot a lot a lot of passes...not the best dragracing clutch but good street clutch...
Old 02-13-2012, 06:26 PM
66chevelle510's Avatar
+1 diamond clutch
Quick Reply: crap! was told i need a Clutch kit...which one?
