What clutch is needed to use LT1 T56 on LS1 motor?
Swapping an LSx motor (LQ9) into a 1979 T/A. Picked up a T56 from a 94 Z28.
Is just a factory LS1 clutch kit needed or will i need to get a bellhousing from an LS1's T56?
I also don't know if they're will be a problem with the slave cylinder.
(This is all for a friends swap so i might need more info)
thanks,
Jeff
thanks,
Jeff
i dont see how it's easier to do all that work then to just sell it and buy a T56 out of an LS1..... my friends got this idea that if he made a custom flywheel (lt1 diameter with ls1 crank bolt pattern) and used all the lt1 clutch kit stuff it would work..... i guess we'll see.
