In need of a cluster gear bearing
EDIT
Found the shaft new for ~220, so i bought it.
I do however need the big bearing on the shaft. If anyone can give me a part # that i could get a bearing, I'd appreciate it. (i know they only sell the complete kit at the t56 shops)
https://ls1tech.com/forums/manual-tr...t56-parts.html
Are you talking the front or rear cluster bearing? LM48458 is the front. I'm not sure what the "big" bearing is? Or are you changing subjects and asking about the mainshft now?
LS1TECH Sponsor
It looks like you already have it figured out, but for others reading this thread we are constantly adding each and every individual item found in a t-56 to our new website. Here is the bearing you were looking for for example: http://www.tickperformance.com/treme...-bearing-race/
Each individual part has links to an exploded diagram and the parts number and description. Transmission parts are listed under specific vehicles to narrow your search down, or you can search the individual number of the component you need from the exploded diagram.
Some of the tapered bearings like you need may be a bit cheaper from a local parts house, but many other bearings will not be readily available locally.
-Jonathan
-Jonathan
-Jonathan
-Jonathan
Side note - got any sweet decals you could throw in?
