shifter raises up when i shift
yup. The torque arm picking up the back of the trans, tears out the mount with power, and sticky tires.
thats why I got the BMR reloc Trans X member. the TA dosnt beat the **** out the tail shaft housing on the trans (bends the mount, and brakes the case too) And the car shifts better overall too, the shifter dosnt move around from the suspension from engine power.
Mine used to bounce up, and I put in a Prothane transmission mount. Problem solved. Don't be afraid to use a poly trans mount with rubber mounts like everyone claims is some nightmare. Been running that same setup for years on 2 cars, plus many friends with the same setup. You will have some initial vibes the first week or two, but after some good miles, the vibrations will go away, and you will have a nice smooth shift
i just installed prothane motor mounts in my otherwise basically stock 99 car and wow did it make a difference in how the car feels when making shifts. it feels much more solid and i am positive it improved my shifting. the trans doesn't move at all anymore, it almost feels like an arcade game.
