Best Organic style clutch ??
Old 05-25-2012, 04:52 PM
80gus's Avatar
Default Best Organic style clutch ??
Im currently doing a ls1 into Toyota truck conversion, this time im fitting a turbo, and want to work out the best clutch available, it needs to have a little bit of give (as in not ON OFF) as its a winch challenge truck. I've been looking at the ACT clutch does any have experience with them, especially keen to hear from any 1 with high torque figures
Old 05-25-2012, 07:54 PM
Exidous's Avatar
How much power are we talking and what is your budget?
Without taking money into consideration:
Stock flywheel and the RST would probably be best if you don't plan on excessive slipping.
Old 05-25-2012, 09:35 PM
ShifterLou's Avatar
I've had great luch with ram stuff over the years.
Their 300/900 disk was a great daily driver and took 540ftlbs flywheel
Old 05-26-2012, 08:38 AM
80gus's Avatar
Same combination is getting 550ish rwhp, i can get a NPC clutch to do the job here in Aus just looking at options.
Old 05-26-2012, 11:28 AM
thesource's Avatar
Do a dual friction setup like a Spec 2+ or something similar for best results. If you have the cash, a street type twin disc is never a bad way to go either.
Old 05-26-2012, 11:37 AM
Rangersltw's Avatar
Look into Monster clutches. Once I got my stage 3 broken in it pretty much drives like a normal clutch.
Old 05-27-2012, 09:46 PM
kenp's Avatar
I have an ACT behind my 383. It did very good until my son hot-lapped it at the strip last spring. It's going to have to be replaced real soon and I also put one behind my C5 Z06 but it has never performed well since I put it in. Don't think I'm going to go that route again so I'm looking at all of the options. I want something that'll hold but I want the pedal feel to be close to stock and I insist upon smooth stock engagement. I don't want any nonsense BS chatter even during a supposed break-in period. My wife has to be able to drive it if she gets the urge.
Old 05-28-2012, 08:41 AM
80gus's Avatar
Thanks for the replies, it seems ACT clutches aint very popular? They good a good wrap, but not many people are using them????
Old 06-01-2012, 04:55 PM
80gus's Avatar
Any 1?
Quick Reply: Best Organic style clutch ??
