Clutch is sticking to the floor. Just bought a RAM adjustable Master and have Q's!
My clutch has been sticking to the floor and until a couple days ago it was still drivable. Now I can't even get it in reverse without it grinding gears... I read a lot about this problem on threads here and through the net so I decided to go with changing out my master cylinder since bleeding the clutch didn't work. The fluid had a lot of clutch dust in it. Any chance I can get some input from people with similar problems in the past or someone who knows what they are doing?
Damn I hope that don't happen to me! haha Yes I did the drill mod, but when I did I found out that the previous owner had already installed a speed bleeder... Oh well. Good to know anyways. I've already ordered the part so I'll just go with it for now.
I replaced the master, slave, line and performed the drill mod before I installed it and still nothing. It would work fine except if I raced it. I had 200k on the stock clutch so I replaced it with a Spec stage III and never had an issue shifting or going in reverse or anything no matter how hard I drove it.
My clutch is good, there's only like 60k on it. I've just been shifting aggressively and messed up the master I'm sure. I hope the slave is good cause I don't want to go through all that trouble. My peddle was good. Never had a problem with it before. Now it sticks to the floor and I have to pull it back with my foot then pump it in order to shift. I had been dry shifting it for a couple days, but I just parked it and have left it alone. Just having my buddy take me everywhere. haha
