Clutch fluid?
I run ATE super blue & it did nothing for me. I had the usual trouble shifting at the track especially when hot. Pedal would get real wierd after a pass & after cool down normal again. This year I went with a monster clutch & QT BH & drilled some vent holes in the front plate so the hot air could escape. Yesterday I had no problems at all, pedal stayed consistent & it was 90 degrees. I would remove the 2 plastic guards from the front of the BH, it gets so hot in the clutch area it boils the clutch fluid by heating up the slave.
I agree that this is relative to heat and that a higher temp fluid is not the only part of the solution. Wrap the headers in a good heat insulating wrap, make sure the lines are routed behind the heat shield, and if you want to use a great fluid that has worked well for me on street and and track application go with Motul RBF-600.
If you don't have headers on the car yet, when you do get some, spend some extra cash and get them ceramic coated. The heat difference is night and day for my clutch fluid because of that extra bit.
