Who has the best shifter?
Old 08-21-2012, 10:59 PM
L84ARACE's Avatar
Default Who has the best shifter?
I'm in the market for a new shifter but don't like a short handle. Any pics and suggestions would be appreciated.
Old 08-21-2012, 11:31 PM
flintwrench69's Avatar
Pro 5.0 is a great shifter, has a slight angle built into the shift lever that I like & I never cut mine down as I like the extra leverage. Youre gonna get a lot of MGW is the best but I have no clue never tried one. I am sticking with the 5.0 cuz it works well for me.
Old 08-22-2012, 01:02 AM
gconnoyer's Avatar
Love my MGW.
Short but still plenty of leverage. If I wanted more all I would have to do is get some threaded rod and cut it to the length that I want.
Old 08-22-2012, 01:37 PM
All-In's Avatar
Location: Just because the voices aren't real, doesn't mean they're not right!
Originally Posted by gconnoyer
Love my MGW.
They make a longer threaded stainless shaft you can buy separately if you want to OR, you can unscrew yours more to make it longer (taller). Just be certain you have at least 12 threads still engaged.
Old 08-22-2012, 01:44 PM
WS6_101's Avatar
I love my MGW as well .. the only complaint I have heard from anyone is that the stick is too far to the right because it is just straight instead of curved towards you, but I don't mind it
Old 08-23-2012, 02:11 PM
L84ARACE's Avatar
I do like the taller shifter but i have heard great things about the MGW .how much adjustment does the MGW have?
Old 08-23-2012, 02:16 PM
Ferocity02's Avatar
There are no adjustments. If you want a longer shaft they are easy to make, just get some rod from a hardware store and thread it. I used a 5/8" rod and bent it to the right shape for my Silverado T56 swap and threaded it to 16mm x 1.5.
Old 08-23-2012, 04:51 PM
WS6_101's Avatar
I believe you can rotate the shifter around the first rod, not sure, but other than that there isn't any. But like mentioned, it would easy to make your own if you wanted to change it in any way. You will love it if you decide to get one though
These are the only pictures I could find of it
Old 08-29-2012, 03:01 PM
L84ARACE's Avatar
Thanks for the pics!
Old 08-29-2012, 10:56 PM
STBZ28's Avatar
B&M short throw. the shifter is just about the stock lenght and it will run you about 150.
Quick Reply: Who has the best shifter?
