Swap T56 for lighter manual?
Road race car and looking to drop some weight. The T56 is huge and heavy and I dont need two overdrives. What's a good, affordable, and lighter weight alternative? With the right gear ratios a 4 speed could even work or a default 5 speed. I'm ignorant to trans options and looking for alternatives to look into. I'm at 365 whp so nothing too extreme.
Thanks
Cameron
Thanks
Cameron
3.7 rear end although I have 3.56 and 3.9 that could swap for. 25" tires. 6700 RPM redline. Lets say no less than 150 MPH top speed.
A T56 is ~135lbs dry, IIRC.
A T5 dry is around 80lbs or so, but with 365whp it's days would be numbered. It could certainly be built to withstand your power rating, but expect to sink a couple grand to get it there. The value of your used T56 might be enough to mostly offset this cost.
The TKO transmissions are around 115ish lbs IIRC, and will handle anything a T56 will, but these cost $$$ as well. An awful lot of work for 20lbs savings, especially considering that the weight sits so low in the car.
What about 4 speed options?
Cameron
Muncie or T10 are only about 75lbs. 1st gears are around 2.6 (wide ratio) to 2.2 (close ratio). They should hold up to that hp easily. Standard upgrades like a supercase or iron midplate will hold more. If you really want to beat on it you can get a Jericho or 101 version with square cut gears and dogs instead of synchros.
https://ls1tech.com/forums/manual-tr...ello-4spd.html
https://ls1tech.com/forums/manual-tr...elete-t56.html
And if you want to shed a few more lbs.
http://www.racingjunk.com/Clutches/1...el-Chevy-.html
I'm in the process of doing a similar swap. I race in American Iron and am putting a Super-T10 in to save 70ish lbs. I'm currently trying to figure out if I can use a UMI/BMR TH350 trans crossmember for the swap or if I'm going to have to make my own.
