Drop the tranny without the engine? Gto t56 in fbody?!?
Can i drop the tranny with the engine still in place?
If so how?
And can i fit a t56 from a gto into a t56 fbody without modifying anything
If so how?
Yes. Remove driveshaft. Unbolt torque arm from transmission, be careful as it will snap up towards the car. Remove shifter, unhook master cylinder line. Unbolt transmission from engine and lastly with a jack under trans crossmember remove crossmember bolts. Make sure you have everything unplugged also. Good luck it's actually pretty easy
