Twin/Triple Disc clutch advice
I'm in the market for a clutch, looking for something to support 1100-1200whp/tq and not be on the ragged edge...going in a 99 F-body , big turbo + 408ci car... im looking at Mcleod Twin, the Textralia Triple w/BFW and the Spec triple... oh and ive considered Monster as well... looking for suggestions on what clutch to go with...not to sure on Spec as I'm on the 3+ now and at 800whp its slipping bad.... any advise is appreciated.
http://www.coloradospeed.com/mcleod-...s1-p-5773.html
http://www.coloradospeed.com/mcleod-...s-p-19731.html
http://www.coloradospeed.com/mcleod-...s1-p-5772.html
These are alternatives as well that our customers have ran and have been happy not listed in any order.
Ones you'll want to look at are the RAM RTrack, the SPEC -Trims and MONSTER Twins/Triples.
http://www.coloradospeed.com/1998200..._id=0&sort=20a
What is your planned usage type? What is your planned torque output (long term)? I know you reference the 3+ and indicate that you are making 800hp but what is your torque output at the wheels or the crank? We have 4 different Super-Twins that will provide great drivability and that offer plenty of options relative to capacity. We also offer mini-twin and triple options too. Let me know a bit more about what you are doing and I will be happy to assist you further. Thanks!
Super-Twin is the way to go...specifically our SC09PT. Give me a call and I will be happy yo assist you further. You can also take a look at the link below for info. Let me know if you have any questions. Thanks!
http://www.specclutch.com/cars/Chevy...999/Super_Twin
ill check it out man and give you a call thanks!! Everyone seems to be recommending the Mcleod, ... Does anyone have experience with the Mcleod Street Twin w/ BFW? I believe they call the kit the B&B kit... Its $1400 ... ill check with Mcleod on that triple your speaking of too... am I wrong to rule out the RSX? Its only $930 and if im not mistaken at that price it utilizes the OEM flywheel.... just iffy on it being enough....
if not the first piece of information on the McLeod "street twin" install instructions it is very close to the top in BOLD letters says to....
"have the clutch assembly match balanced to your applicatin". Yes they sell both external (stock) and internal , aka zero, balanced street twins but still advise the user to have a machine sop confirm the balance of the unit. In my case the billet FW which was a "neutra" balancd FW was off by 25 grms. This was where the holes on back of the FW were for the weight used for a "external" balance car The floater plate & PP did check out good and 25 grms was added by putting 3 of the 4 screws back in where the holes for the weight was taped
My $02 is always have any part be it clutch assembly or rotateing assembly checked for correct balance prior to instal. My experience has been every clutch/FW I have put on ht needed to be "neutral" needed some form of balance adjustment
Mcleod told me mine was balanced, only external balance stuff should be checked iirc. I can tell you that I always check assemblies that I install or that I'm involved with. Zoom and Act have always been within 2, 3, maybe 4 grams off-max. I've never had to do anything with their clutch assemblies, that speaks loads about attention to detail imo. Every other popular ls clutch I've installed has taken a correction, although, it hasn't been anywhere near the amount of correction my street twin took.
I agree that checking it should be standard practice for all installations.
Even though the SNL post says they check balance their stuff..."I" would also on any product that claims it is "zero" balanced. In their case maybe all their stuff is balanced as advertised but given the job of replacing a FW & clutch is tedious, I will spend $40 for a machine shop to confirm.
for stock external balance motors I have had no issues with just bolting on the FW or clutch assembly as is. Internal balanced motors I have balance checked
