4th gear grinding
Old 11-15-2013, 07:58 AM
mean_greenZ's Avatar
Default 4th gear grinding
Has anyone had issues with switching to pennzoil synchromesh and then developing grinding ONLY in one gear? I don't know if it's related or not... But just recently I changed to Pennzoil SM and it's shifted a lot smoother. Last night during a wot 1-4 I noticed 4th was a bit rough going in. Later last night I got on it maybe 3/4 throttle shifting at around 4-5k and it was a bad grind. It still goes in gear but grinds going in. Normal slow driving it doesn't grind at all, it's just when higher rpms are involved.
Old 11-15-2013, 01:57 PM
No one???
Old 11-15-2013, 02:05 PM
TheBlueKnight's Avatar
Do you still have the stock clutch? Mine used to do that with my stock clutch because it uses a self adjusting pressure plate that tends to fail at high rpms. Like you, even at half or 3/4 throttle, if I was in the high rpms like 5k+ it would be difficult to get into third, and 4th gear would be nearly impossible and grind slightly.
Old 11-15-2013, 05:32 PM
No I have a ram powergrip with about 1200miles on it, new gm slave, and tick mc. It didn't start this until after I put synchromesh fluid in it. I was wondering if anyone else had similar issues with this fluid or if it's just mere coincidence.
Quick Reply: 4th gear grinding
