monster vs twin
monster vs twin
Looking to see if I need to go ahead and change clutch to a monster level 2 twin disc. I have a level 6 single now. Going to be around 640 rwhp na and close to 1000 with spray.
Level 6 has low miles ans looks felt great after old motor pulled. Just curious if need upgrade while motor is out.
Also have a tick lvl 2 t56.
We can't resale used clutches, but you are more than welcome to
https://ls1tech.com/forums/manual-tr...clutch-c6.html
Which clutch would be better for me this one ir s level 2 or 3 twin? I know u wsnt a sell but I know yal have good stuff I have a ws6 not a vette..
whats the combo thats gonna make that kind of power? thats some serious power n/a for a streetable motor. at that power that trans you have wont last. need to give rpm a call and they can get u set up so it will
Ls2 erl sleeved 434 alk pro ls7 heads. Cr 12.6 shaft mount roller rockers. Fast 102 ported and painted. Brian tooley cam. In a m6 2000 ws6. With a max if 300 shot.
You dnt think tranny last even fir the na power?
Think you're still a little optimistic on the NA power, but to mirror blue99's point, the trans should be high on the to-do list.....assuming the rear end is stronger than the 10bolt. Trans work for sure AND DEFINITELY opt for a good (great) twin at minimum.
Now im worried going need tranny. Nothings wrong with mine now. Maybe if I send as core be good rebate. Idk if need get magnum or 6060 or whats best. I want long lasting tranny and clutch. I trying do everything once
The clutch is designed to work in all LS platforms. The LT1-R is actually what I'd recommend for severe track duty, it will be your best best for longetivity...racing and doing it once usually don't go together especially when talking about making and actually using the power you're talking about
Is this new clutch a single or twin or triple? Also which would be best tranny to have? T56 magnum? 6060? Or t56 level 6? . I can send my tick level 2 for a core its perfect condition
Looking get one of yals clutches. Dnt want any exploding or anything. And im trying figure out whuch comoany best with builds n pricing btwn tick and rpm. I have a tick already byt trying get info on it
