Tick Speed Bleeder
Tick Speed Bleeder
Finally started to button up the car after the header swap and clutch swap, installed the bleeder on the new slave. Within 5 minutes it was fully bled with a fantastic pedal. Never bled it the factory way, but I imagine that was less than fun where it is placed. Would definitely recommend picking this up if you have a opportunity to install it.
I have Tick's first version of their speed bleeder and bled it from under the car. The one I have doesn't allow for one person bleeding, but still makes the job much cleaner. I don't like making a mess so I put a cup under it, cracked the bleeder, and let it gravity feed while I kept a close eye on the fluid level. When I was done I cleaned out any brake fluid and fed the bleeder hose up under the brake booster and laid right beside the cruise control cable next to the fender.
Moderator
Received 1,837 Likes
Best clutch bleeding experience ever.
I don't know how I ever lived without it, it is THAT good!
My only regret is not installing their master as well when my last LS7 clutch was installed.
