Easy 4l60e to T56 Rev. Lockout Conversion
if your PCM tuner can't flash your PCM and you can't figure what wires to tap into...that would be an option
or...
just wire it to your brake pedal switch for $0, which is what I did 9 years ago on my swap
or...
Im personally gonna rob one of the shift solenoid wires & put the pin into the reverse lockout place on the pcm & have the computer flashed for standard. All you have to do is rob the #47 pin & put it into the #44 slot & trace the wire back & hook it up to the reverse lockout.
auto to T56 in a car that is made for T56 can be done by correct programming and wiring.
certainly that aftermarket part you posted is one option
I also repinned the PCM and used a couple of the wires that used to operate the 4L60, all works like it came that way.
