pedal popped nothing at all now?- OK slave EXPLODED bleeding an empty system?
ok dropping my son off yesterday and was easily driving TA -car has 200k on so I take it easy and I went from working fine to like the pedal isnt hooked to anything now - I have searched seen nothing similar ?? cluch was replaced 40? K ago with new slave and clutch master was replaced 10+15k ago anyone else had an issue like this? I havent gotten it up on a rack yet, was hoping thet cl master came off at pedal or smething simple
thanks for any input guys
OK new parts are on the way- disc, slave and pilot bearing since the slave exploded and all fluid has dripped out should I try to fill slave as much as possible through the bleeder, top of master cyl reconnect and bleed as usual?
PS. I have already drilled a hole in floor so I can easily access bleeder VS. doing it blindly like last time
I never got a call back after phone tag -sorry had to buy my clutch from another vender
bleeding this was a PITA the hole in the floor definetly made it alot easier to access the bleeder fitting - someone should do a writeup in the floor hole mod with pics I would of done it but wasnt thinking it was 95 degrees in shop and late and I was just trying to get this done
Next time you can email me directly and get an almost immediate response, sorry about that.
