Clutch advice
Clutch advice
I'm considering replacing the clutch & flywheel on my '99 SS. The is mildly modified, and generally used for road course events (track days/autox). I'm considering a SPEC Stage 2 Clutch & Fidanza Aluminum Flywheel. Does anyone have any experience with that combination?
TIA
TIA
That is not too bad of a combination.
http://www.coloradospeed.com/1998200...id=62&sort=20a
http://www.coloradospeed.com/1998200...d=411&sort=20a
You can also go with the MONSTER which will have the same characteristics in a clutch.
http://www.coloradospeed.com/monster...s-p-12547.html
or step it up to a level 3 to match whatever stage 2 spec you are looking at
http://www.coloradospeed.com/monster...s-p-12556.html
I think you'll be fine whichever clutch you choose. Both have been proven over the years.
TIA
TIA
Link to Full Line of Clutches
I'm trying to keep the price down because this car is meant as a rag tag track car. I'm also considering the LS7 clutch. Is that safe to use with stock hydraulics on a 4th gen Fbody ? I've read that its meant for different hydraulics (C6) which causing it to drag a bit and break down syncros. Any truth to that?
Thanks
Thanks
Thanks
Thanks
