T56 adapter plate bearing races
I've built two automatics but this is first time on a manual trans. I'm finding the two races in the adapter plate for the input shaft and the countershaft are a slip fit and not a press fit. I don't see any evidence of the races spinning in the bores but just questioning if this is normal or should you stake the bores if you have this condition.
