Did I completely screw up my T-56?
Old 07-13-2015, 04:50 PM
elesquan's Avatar
Default Did I completely screw up my T-56?
I did some upgrades to my T-56 a little over a year ago, adding bronze shift forks, and a new 2nd gear and 2nd gear blocker ring.
I have noticed the trans is a little less easy to shift now than it was before. It feels like the sycro don't grab like before, and I have better luck shifting if I match the engine and trans speed during shifts.
I think the problem is because I used white assembly lube rather than the special auto trans assembly lube.
Assuming this is the problem, could I flush the trans with something and refill with new fluid?
I was toying with the idea of draining about half the fluid, and then add a quart or so of stodard solvent and run the trans with the car on the jack stands for 1 minute. Drain the crap out and add some ATF and run that for a few minutes and draining and refill with fresh ATF.
Maybe the better idea would be to drain and refill with some ATF and add a little friction modifier to it..
Does anyone have some opinions on this?
Thank you!
Old 07-14-2015, 02:24 PM
Exidous's Avatar
You can try and flush it. Trans assembly lube exists for a reason. It breaks down into the trans fluids without messing with it's properties.
Old 07-14-2015, 04:48 PM
elesquan's Avatar
Thanks Exidous, I might give that a try.
Quick Reply: Did I completely screw up my T-56?
