LS1 Stock Hurst shifter
Just picked up a Hugger SS and it has the non Hurst shifter and I can't stand it. Was wondering if the factory GM Hurst shifter with a short stick would give the car a better feel. Have considered the MGW but would rather not spend that much money on a shifter and put it toward other parts for the car!
Is there a huge improvement going from the non hurst shifter to GM hurst? How much do used hurst sell for?
Thanks,
DW
Thanks,
DW
Pontiacerator
Yes, there is a huge difference between the base shifter and the optional Hurst. Fans of aftermarket shifters will bag on the Hurst, but that's because they haven't compared it to the base shifter, which is truly horrible.
Check the parts classifieds. You can find the factory Hurst from $50-100 by guys who have "upgraded" to aftermarket shifters.
Save the manuals!
The worst part about the stock shifters (IMO) is the rubber isolator in the handle. I recall that the stock Hurst has it also and will likewise leave one rowing a limp noodle.
People are also moving on from their aftermarket shifters to try other models, so I expect that better aftermarket shifters should also be out there used.
The original owner of my car purchased a GM Hurst shifter package back in 1999 to replace the stock "noodle" shifter. It came in a GM box with a GM part # but was all Hurst - including the short stick (7-8" long). It shifts well and far better than the stock set ups. It's several inches shorter than stock.
Save the manuals!
The owner of my car purchased a GM Hurst shifter package back in 1999 to replace the stock "noodle" shifter. It came in a GM box with a GM part # but was all Hurst - including the short stick (7-8" long). It shifts well and far better than the stock set ups. It's several inches shorter than stock.
^ This is what I had to do with my '99. I'm glad it went this way, too. The stock Hurst came with the wet noodle stick, also.
Although.... fast forward 18 years later and my Hurst Billet Plus has shot springs. For the price of a rebuild, I can get a new shifter. I'm very interested in the Hinson with their bellevue washers, which should solve this problem long enough for me to be dead and burried in the car.
Save the manuals!
They should be pretty close to the Hurst Billet Plus. They will be wayyyy beyond the stock Hurst. (You'll just want to make sure you do the homework on what you have/are getting.) There should be a thread around here with pictures comparing the two and showing the differences.
