notchy chunky shifts????
i got in my car this morning and started it up and when i put it in reverse it felt normal but when i went to put it in first it felt notchy as i was shifting up. went to second and the same thing happened notchy . it does the same through all 6 gears when im in motion. i have a hurst and it just feels a little notchier than normal! when im sitting still rowing through the gers it isnt notchy or chunky. could it have anything to do with a bad shifter solenoid????
Hydrolics.. Your Pressure Plate is not Disengageing properly and it feels notchy because your using too much of the trans syncro's to get you into gear... If you have not done the drill mod, do that. Next wrap the steel braded line with header wrap to keep heat away. Use Wilwood 570deg brake fluid for fluid, keep the heat more at bay... Next change your trans fluid with new stuff. Follow these steps and you should have a smooth shifting trans from now on..
Clint
Clint
i think i might have something similar. I'm very new to driving a stick so i might just suck, but every now and then 2nd gear seems not to want to go in. If i put it back in neutral and try again it goes in. any ideas, or do i just suck?
PS. InstallUniversity.com has a good write up.
We dont have shifter solenoids so thats not the problem. Check your trans fluid and the master cylinder. Was it cold this morning in D'ville? Mine feels that way sometimes when its cold.
Mine feels chunky and doesn't want to go into gear almost all the time. It will sometimes fool me that its all the way into gear but its only half way!! I think HUGGERORANGESS is right. I am going to change my clutch and trans fluid and rap the lines. If this isn't enough I am going to replace my slave cylinder with an 02' model. If I still have the problem I am going to drop the trans and see what the syncros look like.
thats funny cause when i had my car inspected at a top notch dealership they told me i had a leaky shifter solenoid
