Pilot bearing won't come out
just what it says. I've been beating on it with a slide hammer and just pinched the **** out of my hand so I figured it was time to take a break and ask for help. The damn thing won't budge.
I used a slide hammer with the pilot bearing removing tool. I had to grind down the claws that hold the pilot bearing, but once I used the tool/slide hammer, it literally took like 3 whacks for it to come out.
The first one I did came right out after a little bit of heat and a few hard hits. This one won't come out for anything. Also what store sells a high quality bearing?
Might be too late at this point as the bearing is mangled but there are two alternative methods that haven't been mentioned.
1) Fill (I mean FILL) the hole with light grease Get a old input shaft, extension or other rod that fits tightly. put the rod in a little bit to compress the grease and then wallop it with a hammer. The grease should force out the bearing.
2)Get a torch and heat the bearing (try to avoid heating the flywheel) up until it is red hot. As it is cooling use the slide hammer to pull it. The idea here is that the bearing will cool faster than the flywheel, shrink a little relatively and allow you to extract it.
https://ls1tech.com/forums/manual-transmission/330495-pilot-bearing-removal.html
Good Luck!
I finally got it out. Barrowed a bigger slide hammer from another tech at work and went to autozone to barrow the attachment. I tried to get the MAC tool off the truck today, but he can't get it to me until monday.
