Baddest manual tranny for a street monster car.....?????
Title says it all.
HP/TQ you ask??? Lets say 1,000 RWHP. What will handle that with NO problem at all? Races from a roll only.
Car: WS6
Thanks.
Car: WS6
Thanks.
http://www.rocklandstandardgear.com/...iles/frame.htm
They have a T56 in there that they claim can take 750+ HP
http://www.ddperformance.com/GM%20T56.htm
I've heard a lot of people praise these guys also.
So when a tranny builder lists torque ratings for a tranny, are they talking a hard launch? Or what?
Because hitting it from a roll I would assume that rating can go way up.
In the past, I have spoken to the folks at Keisler Trans.
I was told that torque ratings are for the tranny in top gear.
Since the trans can handle more torque in the lower gears, this means a trans rated for 750 ftlbs should be able to handle quite a bit more in 1st thru 4th, where most roll races will occur.
Originally Posted by LOnSLO
THE baddest *** manual tranny for the street is a Lenco ST1200. Are you talking T56 here?
SSU'S Vice Mod
That won't fit into an F-bod without hacking and sawzalling. Besides, custom fabbed bellhousing/scatter shield and probably at least a 2 disk clutch to make it work. Bad ***, yes, expensive, yeah. Is there anyone that makes straight cut gears for a t56 box? Just scrap the synchros and flat shift it.
The T56 is a pretty stout piece . We offer a unit rated well into the 750 + trq but would probably handle a 1000 hp as long as its not from a hard nitrous hit . Superchraged or turbo doesn't hit as hard and is easier on the drivetrain .
Just do what im doing... Tex Racing T101A 4 speed non shyncro 300 + avalible gear ratios uses Mcleod 8710 bellhousing and adj master Tilton clutch, flywheel and throw out bearing...gunna use a speedo conversion from Yank ,shifter set back and off set is totally adjustable its within 1 inch of the T56 right now..thing weighs 70 pounds full of oil...
Originally Posted by antz01ta
and making 1000 rwhp is????
For these people anyway, try 1,360 RWHP (approximately) from an engine that will fit into an F-Body and is MUCH more reliable and MUCH stronger than any LSx based engine.
http://www.bankspower.com/twin-turbo-products.cfm
