major problem! clutch install went wrong.
ok so i put in a mcleod single disc, 01 slave, and ram adjustable master. i am trying to bleed it and no matter what bubbles keep coming up thru the mityvac. i follwed the write ups on here word for word. buuuuut the clutch pedal is very strong and feels great. no sticking or anything. so i figure screw it. i turn the car on while its still in the air and go to put it in gear--very hard to get in but i do so with some effort. clutch is still to the floor and wheels start turning so i take it out of gear. try to put it in reverse and i have to slam it in. sooooooo im thinking that maybe i need to shim the to bearing??? what do u think? bad hydraulics out of the box perhaps?? please need help because im not in the mood to pull it apart again and want to know what im looking at b4 i do so.
Try to bleed it with the bleeder valve on the slave and see if you have any air in the system first. You shouldn't because you said the clutch feels good. After that I would try to lengthen the rod on the master a good bit and see if it will go in gear any easier.
I've seen bubbles continue to come up using the mityvac. Seems that sometimes it will suck in air around one of the lines because too much vaccum. I put another zip tie around the reservoir line where it connects to the master and it solved that problem.
i just tried to make the rod longer and by accident i pulled up on the pedal and it made some clicking noises like it was skipping on a gear and the whoe pedal moved towards the driver. so now my clutch pedal is like an inch higher and in turn making any adjustment to the rod a cancel out. how do i get this pedal back down where it needs to be now??
i talked to mcleod 2day and they said in no way should the single disc need shims. he said i may have bent the disc but id have to imagine this is pretty difficult to do. no looks like no one can diagnose this for me so its going to have to come completely apart again. anyone who could have any idea PLEASE chime in.
How did it act when you lengthened the rod. Still hard to get in gear?
The gear stripping sound you heard was the clutch switch jumping teeth in its housing. You can adjust it for pedal height.
As for the disc being bent. Did you get the tranny straight in or did it flop around a bit during the install. I have had a hard time getting a tranny to line up and it flopped around quite a bit and still didn't have any problems. I find the bent disc thing kind of hard to buy. I wish I could tell you something concrete but without looking at it I'm at a loss. Sorry man and good luck, I know it can be frustrating.
my dads not buying the bent disc either. and hes been a mechanic for 30+ yrs. im having a guy from the local hot rod shop come by the house--he thinks he can bleed it. i dont. i moved the car last night to get it on a tow truck and there was a big puddle of dot under it and smoke was coming from under the car. i had to put it in gear then turn it on and the car was rolling b4 it finshed cranking. i think my new slave is bad. at this point im so tired of looking at it i might pay someone to redo all the work i just did.
oh and no it didnt do anything when i legthned the rod.
I'd say don't give up, but I guess you already did. I was in the same boat as you. I couldnt bleed the clutch at all, nothing worked. So I tried my own method of pumping fluid up through the quick diconnect fitting. Anyways, I think you need to shim the slave. It's obvious it's not disengaging completely.
when u guys say shim the slave dont u mean the to bearing? can u just put a shim behind the slave instead of pulling it apart? and where do u get them? and why would have have to on my car when this kit goes into every other car without shimming.
