popping out of gear question
Old 08-03-2005, 06:17 PM
LS1_Fonzie's Avatar
Default popping out of gear question
I have a 98 z28 with 78,000 miles on it. It occasionally pops out of gear when I drop it into 4th during normal driving conditions. The car still has skip shift and when I go from 1-4 I have no problems at all. The problem happens when I go from 3 to 4. Shifter will begin to shake and pop out, I'll quickly take it out and put it back into 4th and it will be fine. Is it my shifter? It came with the factory hurst shifter. A friend said it was my synchros. All the other gears are fine, no problems with them. Seems to only happen after driving the car for about an hour. Any advice would be greatly appreciated.
Old 08-03-2005, 06:41 PM
Red_Dragon's Avatar
Your 3/4 shift fork is probably bent a lil bit causing the synchro to slip off the gear because in 98 the shift fork was alum. In 01-02 gm changed it to steel like what the cobras and vipers were already using. You can pick up a steel shift fork for like $50.
Old 08-03-2005, 06:42 PM
1320_Racing's Avatar
Well that is how mine started now it will not go into 3rd or 4th
Old 08-04-2005, 12:04 AM
5w20's Avatar
sounds like a bent shift fork
Old 08-04-2005, 02:01 AM
LS1_Fonzie's Avatar
Do I go to GM for that or can I buy it somewhere else?
Old 08-04-2005, 02:40 AM
Red_Dragon's Avatar
You can get it somewhere else. I got mine here. I know there are other places out there I just don't have many links since I'm on an old comp I don't use much. Search the forums I'm sure you could find some links for T-56 upgrades.
Old 08-04-2005, 02:48 PM
ROCNDAV's Avatar
Here's another
http://cgi.ebay.com/ebaymotors/T56-3...spagenameZWD1V
Old 08-05-2005, 02:38 AM
LS1_Fonzie's Avatar
So what is involved with installing the shift fork? I'm not very mechanically inclined so any dismantaling would be done by a shop. Any idea of cost for labor?
Old 08-05-2005, 03:23 AM
Phoenixta99's Avatar
To operate on a shift fork, Trans has to be totally ripped open: about $150 to $200 at a descent Trans shop. Shift forks shouldnt be too expensive, but if it were your synchros, youd hear it!
Quick Reply: popping out of gear question
