Can clutch life be prolonged?
Old 10-20-2005, 04:23 PM
Shpoone's Avatar
Default Can clutch life be prolonged?
OK, I know that my clutch is slipping, and needs to be replaced. However, I was wondering if changing out the fluid, bleeding the system real good, etc. would make it grab a little better in the short term? Also, if the slave ends up shot, would I feel the same result as if the clutch disc is slipping, even if it's still OK?
TIA
Old 10-20-2005, 08:50 PM
2K2WS6TA's Avatar
You don't need to do all that, just drive like grandma, no hard takeoffs, hi rpm downshifs, flooring it in 6th, just drive it easy, I babied my clutch for another few hundred miles of use (it was pretty damn worn) and you'll probably need a new flywheel after trying to eke out the last bit of life from the clutch
