Mcleod clutch, what do I need?
wrencher
I would definately say a McLeod master is needed for the twin disc.
It is not a diaphram spring pressure plate. It's a coil spring/lever style pressure plate for the twin's. They are suppost to require the special master.
I have the set up love it. Had to rebuild the master, but now it is like a switch on/off.
wrencher
Well Mcleod/CNC masters are known to be problematic in the out of box form. Rebuilding them seems to be the cure. (search here)
Now mine is like a switch it releases in such a short amount of pedal travel, it takes a little getting used to. I drive it on the street & lauch it 5K+ w/slicks at the track, the clutch has been good to me.
Where did you get your rebuild kit? I found it somewhere before, but now that I'm actually ready to do it, I cannot find the site. I think Red mentioned it was like $28. from him but cheaper from his vendors. So I called every vendor that sells ST's and no one has a rebuild kit.
Thanks,
Jeff
Thanks,
Jeff
Thanks,
Jeff
http://www.thunderracing.com/catalog...vid=3&pcid=266
I have been running a Mcleod single disk for ever and have a mcleod adjustable master cylinder with over 75K miles on it and it works perfectly, never had a single problem with it. I've raced it on slicks with 6K+ clutch dumps and a ton of daily driver miles without any problems. You can replace the disk itself for 125 bucks from Mcleod if it ever wears down. I have a Mcleod Single Disk with their steel flywheel, and a mcleod adjustable master and an 02 slave cylinder.
Cheers.
Cheers.
