How many people are running an LS7 clutch RIGHT NOW?
How long have you had it in?
How do you feel about it?
These should be the correct part numbers.
part #24236500 is the ls7 clutch kit
part #12571611 is the ls2 vette flywheel
Did you use any other parts?
I plan on putting one in after the tax refund comes back.
Originally Posted by bad6as
give us the freaking part numbers!!!
did you reuse your pp and f/w bolts?
24236500 ls7 clutch kit
12571611 ls2 vette f/w
the slave & m/c & t/o bearing are all stock 01-02 pieces.
all of the work on my car was done by a local GM dealer.
hope this helps
so is teh ls7 clutch kit part number
24236500,<----dosent come up on fried beans, but does on gmparts direct to
or
25233650<---- comes up on fried beand and gm parts direct
the 1st and 2nd part numbers come up as clutch plate on gm parts but are 2 different prices the 1st number is $260 and the 2nd part number comes up as $273
or
Anybody have the slave and pilot bearing numbers or know where to get them other than calling a dealer? gmpartsdirect isn't much help unless you have a number. Also, is the throwout bearing and slave one part or are they separate? Thanks
for less $$ go with the ls7 clutch w/ a ls2 vette flywheel 01+ master and 01+ slave and a new piliot bearing, it will hold more power, and drive great. mine is on my floor wating for the shop to fit me in..............
